When setting multiples Y scales visible/not visible on a XY graph with autoadjust scales option enabled, labview bugs after a while and starts doing strange things (attached 1).
I made a VI to manually fix the scale positions wich seems to work in a separated VI (atached 2) but fails to work when integrated in my application in which im setting some property nodes for the graph in other parts of the program aswell.
Any clue?.
