Hello rvleadmal,
Thank you for your question regarding displaying multiple graphs on a plot. You mentioned that the scales were getting shifted away from the graphs. I took a look at the code that you sent me and made a few changes in the second loop. I also reduced the size of the viewing area in the graph indicator to allow room for the y-scales on each side. I set the first four values in the left enum control to be visable on the left side of the graph and the last four values in the right enum control to be visible on the right side of the graph. This is just for demonstration purposes. You could create separate enums for scales on each side of the graph if you would like.
Other resources can be found on the ni.com website by clicking the support ta
b at the top of the home page. Then search from Technical Resources at the top of the page for your topic. I hope this helps! Let me know if you need any other support with this issue.
Shea C.
Applications Engineering
