YASKAWA operation modes
YASKAWA EtherCAT manual mentioned the following operation modes, could anybody help to explain?
• Profile Position mode
• Homing mode
• Interpolated Position mode
• Profile Velocity mode
• Torque Profile mode
• Cyclic Sync Position mode
• Cyclic Sync Velocity mode
• Cyclic Sync Torque mode
(4,372 Views)
Is your query related to LabVIEW?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(4,340 Views)
Accepted by topic author TRYPSIN
Hi TRYPSIN,
Those look like modes specific to the YASKAWA device and not EtherCAT in general. I would recommend contacting the company that created the manual you saw them in (probably YASKAWA).
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(4,333 Views)
I asked somebody familiar with servo motors, these modes are not YASKAWA specific, just general mode definition according to CiA protocol
(4,202 Views)
So they're not commands specific to EtherCAT or YASKAWA.
But possibly specific to CAN in Automation.
CiA would be a completely different (on all 7 levels) OSI stack as compared to EtherCAT, e.g. different cabling.
Andrew T.
(4,192 Views)
