YY BMS Data acquisition
Good Evening,
I am extracting BMS data from YY BMS Battery Pack(PDF Attached). I made a VI but not able to get exact values. I am bit confused in Lower & Higher bit of data.I am attaching Data Screenshot and VI.
Thank you in advance
(2,005 Views)
Hello there,
Are you concerned about the results you are getting in the Data string indicator? What were you supposed to get?
(1,930 Views)
We are supposed to get the above data in LabVIEW.
(1,902 Views)
Can you please tell me which indicator in your VI doesn't show the expected data and circle out the data you are supposed to get from the picture you just sent so I can help you?
Thanks.
(1,867 Views)
