08-08-2017 09:35 AM
I have MX100 from yokogawa device which i want to configure. I used NI device driver of MX100 to configure the system. But unfortunately not able to configure the device. I also used example of YKMX100 App Config Range.vi, even with this unable to configure.Could someone suggest me how to configure MX100 devices using LabVIEW. Below attached my VI. Also if suggest me how to verify whether device is configured using LabVIEW
Note: I am using MX100 standard to verify configuration.
08-09-2017 07:54 AM
Any update on this? i have posted before this on different topic but i did not get reply for any. Please let me know who is the right person to contact on NI MX100 issue if there is no answer in this forum 🙂
08-09-2017 08:29 AM
Did you checked if your connection is OK ? You can try to set the reset input of the Initialize VI to true.
Kees
08-09-2017 08:46 AM
Connection is OK and I tried by setting reset as true, still no result. I am not getting any error but I do not see configured value either.
