Yokogawa UP55A controller Help needed
Dear Kevin,
1. It is In house developed program
2. From another file, I give the time schedule as input.
3. It works properly for heating and reached the desired Set value but on cooling down I wanted it to decrement by the rate of 20degree per minute. Is there any cooling setting can we do in Controller UP55A like heating. If I am not there is a heating/Cooling mode option available in communication manual of UP555A but I can make an understanding of how I will do it in LabVIEW.
Taufeey
Message 11 of 13
(661 Views)
Dear GerdW,
Best Regards,
Message 12 of 13
(663 Views)
Hi Taufeey,
I guess the answer is found in the manuals of your device. Did you read them?
Cooling should work the same way as heating. Maybe you just need to switch the operating mode using a special command, but again: the answers to your problem should be found in the manuals of your device. Did you read them?
Message 13 of 13
(653 Views)
