You cannot write data outside the boundaries of your waveform.
Dear,
Each time i run the program try to writh some file , a alert will pop up and said You cannot write data outside the boundaries of your waveform. Status Code: -200311.
What should i do ??
With regards
David
(2,748 Views)
David
What are you talking about?
cheers
Pawel
(2,738 Views)
Perhaps if you posted your VI (or a simplified version that exhibits the described behavior) and described your situation in a little more detail we would be able to better assist you. Are you using a waveform graph in your application? Thanks!
Robert Mortensen
Software Engineer
(2,719 Views)
