You must have the .NET Framework 1.1 Service Pack 1 or later to use .NET functions and applications
Well, the logs look fine except that I would expect to see one, such as
*** Assembly Binder Log Entry  (1/31/2007 @ 2:58:35 PM) ***
The operation was successful.
Bind result: hr = 0x0. The operation completed successfully.
Assembly manager loaded from:  C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorwks.dll
Running under executable  C:\Program Files\National Instruments\LabVIEW 8.2\LabVIEW.exe
--- A detailed error log follows.
=== Pre-bind state information ===
LOG: User = xxx
LOG: Where-ref bind. Location = C:\Program Files\National Instruments\LabVIEW 8.2\resource\NationalInstruments.LabVIEW.dll
LOG: Appbase = file:///C:/Program Files/National Instruments/LabVIEW 8.2/
LOG: Initial PrivatePath = NULL
LOG: Dynamic Base = NULL
LOG: Cache Base = NULL
LOG: AppName = NULL
Calling assembly : (Unknown).
LOG: This bind starts in LoadFrom load context.
WRN: Native image will not be probed in LoadFrom context. Native image will only be probed in default load context, like with Assembly.Load().
LOG: No application configuration file found.
LOG: Using machine configuration file from C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\config\machine.config.
LOG: Attempting download of new URL file:///C:/Program Files/National Instruments/LabVIEW 8.2/resource/NationalInstruments.LabVIEW.dll.
LOG: Assembly download was successful. Attempting setup of file: C:\Program Files\National Instruments\LabVIEW 8.2\resource\NationalInstruments.LabVIEW.dll
LOG: Entering run-from-source setup phase.
LOG: Assembly Name is: NationalInstruments.LabVIEW, Version=8.10.11.20491, Culture=neutral, PublicKeyToken=null
LOG: Re-apply policy for where-ref bind.
LOG: Binding succeeds. Returns assembly from C:\Program Files\National Instruments\LabVIEW 8.2\resource\NationalInstruments.LabVIEW.dll.
LOG: Assembly is loaded in LoadFrom load context.
This is the successful loading of the NationalInstruments.LabVIEW.dll assembly via the LoadFrom command. Then you should also see on such as
*** Assembly Binder Log Entry  (1/31/2007 @ 3:02:53 PM) ***
LOG: User = xxx
LOG: Where-ref bind. Location = C:\Program Files\National Instruments\LabVIEW 8.2\examples\comm\dotnet\Calculator.dll
LOG: AppName = NULL
LOG: This is an inspection only bind.
LOG: Attempting download of new URL file:///C:/Program Files/National Instruments/LabVIEW 8.2/examples/comm/dotnet/Calculator.dll.
LOG: Assembly download was successful. Attempting setup of file: C:\Program Files\National Instruments\LabVIEW 8.2\examples\comm\dotnet\Calculator.dll
LOG: Assembly Name is: Calculator, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null
LOG: Binding succeeds. Returns assembly from C:\Program Files\National Instruments\LabVIEW 8.2\examples\comm\dotnet\Calculator.dll.
For the calculator assembly itself. Then, if you run the VI, you should see a similar sequence, except that DNCInterface.dll should not be loaded again.
So, you keep talking about running the VI. Let's start with the basics. Can you open a blank VI, drag and drop a .NET constructor and get the assembly list to show up, or do you get the error message?
Message 11 of 15
(1,846 Views)
First of all, I created a .NET classlibrary project, which contains simple summation function of two double variable. And then, I opened a new blank VI. I drag and drop a .NET constructor. When I tried to get the assembly, I got "The selected file is not a .NET assembly, type library or automation executable" error message. What do you think about this error message? I tested this classlibrary assembly in another .net windows application, It's working.
Message 12 of 15
(1,826 Views)
And also, some logs are created in fusionlog viewer
Message 13 of 15
(1,819 Views)
Same problem here, Im using Labview 8.2.1 and NI-DAQmx 8.6 on a laptop with Vista.
I've installed all the softwares/drivers (several times), even upgraded my .NET to v3.5, etc.. in order to get labview to detect the .NET framework but nothing seems to do the trick 😞
The .NET framework 3.0 is included in Vista so I really dont know what else I can do.. especially since I have absolutely no problem when using the same version of Labview and NI-DAQmx on a computer with XP.
Thanks a lot for your help
Message 15 of 15
(1,492 Views)
