Zebra ZD420 - checking for "downloaded" fonts
@Mark_Yedinak wrote:
I think I need to look at Rolfk's suggestion so I can eliminate the need for the lvimptsl.dll file. This is a bug that NI introduced several releases ago. It has been reported but apparently NI isn't concerned about fixing it. I don't recall which version of LabVIEW broke this but at one point I never had to include the lvimptsl file in the build spec. Then they broke it and obviously given your experience it has not been resolved.
I'm not sure when and if it was safe to call the lvimptsl functions in a build application. It is located in the resource directory and all those DLLs are supposed to be also in the root directory in the LVRTE installation. However I can't see it in any RTE installation back to even 8.x and 7.1. So the other alternative is that it was before somehow added by the application builder to the built despite being located in there, maybe through special casing and it somehow unlearned to do that, or an even more likely cause, it was moved from the support VI library folder for the Import Library Wizard deep inside the resource folder into the top level resource folder and because of that fell under the Application builder exclusion rule to not add it to a built executable/shared library. And that fact got lost in testing, it's esoteric enough to not think about during that quick fix, to resolve for instance a problem where the LabVIEW IDE may have somehow searched for that DLL under certain conditions. Moving it into the resource folder guarantees that it is found almost immediately when the path to the DLL gets somehow hosed in the VIs, since that is one of the first locations LabVIEW actually looks for things. But that search doesn't apply recursively to all the subdirectories in the resource folder as that would make things very lengthy very fast.
The dirty solution would have been to add a special exclusion of the exclusion for files in the resource folder in the Application Builder for this file. The cleaner solution would have been to promote lvimptsl as an official part of the LV RTE and add it to the DLLs that get installed in its root folder.
But my solution is to avoid this shared library altogether by directly calling the LabVIEW MoveBlock function myself.
Rolf Kalbermatter  My Blog
Message 21 of 31
(1,837 Views)
Going the VSA Driver Wizard path to talk to USB devices seemed like a great idea back around 2000, if and only if you could get the low level protocol specifications for a device. But it's not anymore.
What are your chances to use the driver that Mark posted? That route avoids the problem as it accesses the USB interface apparently through WinUSB rather than trying to install its own driver.
And you of course immediately ask why didn't NI use the WinUSB path themselves. And the answer is likely a combination of several reasons. First WinUSB was and still is not exactly the official Microsoft way to do USB business. They were initially very reluctant to properly document this, as they did not want to cement the interface in stone, to be able to modify it at a whim for their own purposes whenever they felt like. And NI already had been busy developing their own device drivers for all their hardware for quite some time, so leveraging that knowledge was not that a strange idea. Developments in the OS market made it however mandatory that device drivers needed to get signed to avoid the situation that some malware can easily install its own super power backdoor into the OS kernel without any notice by the user. Unless they can steal the private key from a well established software provider (such as what recently happened for several big Android software providers), the user at least gets a warning that an unsigned driver respectively a driver signed from an untrusted source is attempting to get installed. In Windows 10 it is even impossible to install unsigned drivers unless you start up the system in a special debug mode. And a VISA driver wizard driver is also simply a device driver, even if it is in fact only the INF file installing the VISA USB raw interface for a specific device and vendor ID.
Message 22 of 31
(1,836 Views)
Thanks Rolf,
I have downloaded Marks driver and going to try it out later this evening. Hopefully I can get it to work on my development computer.
The one issue I have to be careful of though is that my customer will need to be able to install any software so if its too complex they will not be happy.
Thanks again,
John
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
Message 23 of 31
(1,816 Views)
The USB driver I uploaded earlier is pretty easy to deploy. You need to include the driver itself in your installer. Best place to put it is in the folder "C:\ProgramData\Zebra Tools\Drivers". I also include the file "lvlib.dll" in that same folder. Last item which needs to be part of your build spec is add the file "lvimptsl.dll" to your project. This file can be found in the "resource" folder in the LabVIEW folder ("C:\Program Files (x86)\National Instruments\LabVIEW XXXX\resource" for example). Create a destination folder called "resource" and place it under the root folder for your project. Then mark this as "Always Include".
This should be all you need to do. The hardest part to manage after that is getting the correct PID for the specific printer model. I have used USBview in the past to get this information. There are too many for me to post them all here. I generally use an ini file to store the USB settings for a specific printer. The library also has functions which can list all of the Zebra printers currently connected to a computer. If there is a single printer simply pick that as the printer and connect to it.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 24 of 31
(1,797 Views)
Where do I find this elusive DLL? I see that this function exists the the file lvrt.dll in the LabVIEW version specific folder (C:\Program Files (x86)\National Instruments\Shared\LabVIEW Run-time\LabVIEW XXXX") but this seems wrong since it is using a version specific file. There is also the NILVRuntimeManager.dll file in the "C:\Program Files (x86)\National Instruments\Shared" folder that has this call as well. This seems more generalized to use. But when configured I never see the label "LabVIEW:MoveBlock" as shown in your post. It always includes the name of the DLL file itself.
Mark Yedinak
LabVIEW Champion
Message 25 of 31
(1,781 Views)
Hello Mark,
Would it be possible for you to post your file in Labview 2014?
John
Labview Version 8.5
Labview Version 8.6
Message 26 of 31
(1,775 Views)
I working on it. I am just incorporating the changes suggested by Rolf which will make distribution easier. I should have it posted tomorrow.
Mark Yedinak
LabVIEW Champion
Message 27 of 31
(1,752 Views)
Use “LabVIEW”.(without quotes but case matters) as library name and LabVIEW will link to whatever is the current runtime library.
It’s LabVIEW.exe in the IDE but lvrt.dll or fflvrt.dll, or something else on non-Windows platforms but that special keyword as library name makes LabVIEW always resolve to the right thing.
Message 28 of 31
(1,744 Views)
Also, those images in my post are snippets. Don't you have access to LabVIEW 2018 or newer to open them?
Message 29 of 31
(1,712 Views)
Thanks for files Mark which I have only just got around to using. Took a few attemps but got there in the end using your 'Test Driver.vi'.
Specifically I have used the 'Get printer list' then 'Connect' and finally 'send'. This sequence works fine printing the data and QR code to my Zebra printer.
I am now looking at your suggestion of placing the printers connection information into an ini file but will need to do a bit of research because its a new one for me.
I have also used RolfK's replacement vi's instead of usin lvimptsl.dll and they have worked fine.
For reference I found the lvzlib.dll on my computers at:- C:\Program Files\JKI\VI Package Manger\Support\
Thanks again, John
Labview Version 8.5
Labview Version 8.6
Message 30 of 31
(1,540 Views)
