Zebra printer - Printing from LabVIEW using ZPL commands....
@shew82 - This is fantastic and it worked perfectly once I figured out what I was doing. Thank you for the tip!
Message 91 of 165
(5,411 Views)
@Mark_Yedinak
Have you ever finalized the release of your software that does not require replacing the Zebra drivers with a custom inf?
This would help many of us a great deal!
Message 92 of 165
(5,315 Views)
@WVisser - the method that @shew82 posted does not require replacing the Windows drivers. I have been using the two side by side for a while now.
Message 93 of 165
(5,296 Views)
No, I have not recevied the final clearance from our legal department.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 94 of 165
(5,263 Views)
Appologies if this has been addressed but what about using a serial port instead of USB? That way you can print from serial (automated) and from USB (from zebra designer).
Message 95 of 165
(5,250 Views)
Mark,
Any update on releasing the Zebra Driver?
Eldon
Message 96 of 165
(5,040 Views)
No, not yet. I need to check back with our legal department.
Mark Yedinak
LabVIEW Champion
Message 97 of 165
(5,006 Views)
The SharpZebra based solution not only does not need custom drivers, but also works for any Zebra printer interface - serial, USB, parallel, or network.
(Note: I personally only used it for USB and serial, but as it goes through the Windows printer driver, is should work for the other intefaces without any code changes)
Message 98 of 165
(4,996 Views)
Do you have any example code?
Eldon
Message 99 of 165
(4,962 Views)
Unfortunately not any more - I developed a wrapper library at my previous employer, so the code stayed behind when I left.
Message 100 of 165
(4,940 Views)
