Zoom FFT Real Values
I am having issues running my VI using Zoom FFT and plotting the Real Values of the FRF.  I generated a signal with noise and am attempting to focus on the region between 0 and 500 with the most amount of lines possible (is there a max number of lines that LabView can preform?).  When I attempt to graph the real values of the FRF I get a blank graph.  I attempted to output the Y values of the real portion of the FRF in an array and get all zeros.  Can someone please advise?
(3,545 Views)
Hi Hova,
I ran the VI you posted and plotted data to the Real Part of FRF graph without any issue. What zoom settings are you using?
Aaron P
http://www.ni.com/support
(3,506 Views)
Ha really? Could there be an issue with the version I am running? Version 8.2? Whenever The program runs nothing is plotted except the original graph.
hova
(3,479 Views)
Hi Hova,
Have you seen this on multiple VIs or just with this VI? If it's just this VI, try copying the block diagram from this VI to a fresh VI and running it.
Aaron P
(3,461 Views)
I just tried copying and pasting the block diagram into a new VI and it still doesn't work.  Any other suggestions??
(3,446 Views)
