Zoom in on section of intensity graph?
Hello all,
I need to be able to zoom in on a section of an intensity graph.  I know of the graph pallette but what I want to do is have the original graph, then select a region on the original to zoom in on which will  show up in another graph indicator so I have my original plus the zoomed in region.  Along with this is it possible to have a square or something on the original that will show the user how large and what area he/she is zooming in on?  I have tried to alter some of the shipping vi's like "cursor.vi", or "smith plot with zooming" but have been unsuccesful.  I have attached an example vi that I wrote that displays 2 intensity graphs.  Can any of you point me in the right direction so I can accomplish this display idea or can you let me know if this is possible?
Azazel
Azazel
Pentium 4, 3.6GHz, 2 GB Ram, Labview 8.5, Windows XP, PXI-5122, PCI-6259, PCI-6115
(4,542 Views)
Zooming should be as simple as passing a subset of the intensity graphs data array to a new graph.  You can make it as robust as you want by using the event structure to allow the user to select a subsection if you want.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(4,538 Views)
Using X and Y Scale range properties will allow you to see the Zoomed boundaries as shown in the modified version of your example VI.
Lynn
(4,529 Views)
Is there a way to send the data in the selected region into a new array?
(4,411 Views)
Just wire the graph into an "Array Subset" node.  Using a property node of the Intensity Graph, as was done in this example, the inputs to the Array Subset node (top to bottom) are:
- YScale.Range.Minimum
- (YScale.Range.Maximum - YScale.Range.Minimum)
- XScale.Range.Minimum
- (XScale.Range.Maximum - XScale.Range.Minimum)
The output is the subarray you want.
--John
(4,400 Views)
