Zooming an Imaq Image
Looking for suggestions..... I am trying to fuse optical imagery with GPR data.  Have been able to generate a representative image from basic GPR data.  I am trying to zoom this resultant GPR image using the resample function to spatially match the optical image so I can fuse the data (already done).  But the large image size difference results in a greatly, and unusable,  pixelated GPR image. I am trying to correct this.  I am currently trying to convert the image into a picture control which then I have an example of good quality zooming. But then I can not use the AND/OR type functions to accomplish the fusion.  Any other thoughts on quality image zooming?
(2,946 Views)
Once you have a digital picture, the number of data points (pixels) you have is fixed.  Suppose you have 1000 x 1000 image, and you want to zoom it 10 times to view the center 100 x 100.  This means that you are discarding 99% of your data and need to "smear" the remaining 1% across the entire 1000 x 1000 space.  There are 2D smoothing functions that can help "de-pixelate" the resulting image (much easier to do with grey-scale than with color), but you are still forced to deal with "making up new data".  Note that there are such functions in the Vision palette.
Bob Schor
(2,907 Views)
Thanks for the thoughts,
I am trying to zoom the GPR image a long way but the resample function seems to simply duplicate pixels, even though it appears to hide this with a few built in algorithms.   I know there are other methods such as using the r-squared concepts but you just confirmed that there are no other ways built into Labview…. Nuts.
Everything I always thought I knew and read about GPR, and the massive amount of data it produces, was just wrong.  As is, I don't think what I am doing useful.  Disappointed but I can't change the GPR and perhaps this is why data fusion between Optical devices and GPR is not being done.
(2,900 Views)
