a question about multicolumn listbox
Hello!
I want to use in my diagram the same block to display arrays, the multicolumn listbox.
I have a matrix with only one column and I want to display or to show the elements with multicolumn listbox, but it makes an error (this bolck needs a 2D array).
Someone knows what can I do to represent this kind of matrix (1 column matrix) with this block.
Thanks!
Larson
(2,537 Views)
Sorry....I want to ask too the same question for a vector (a matrix with a 1 row)
Thank you!
(2,533 Views)
Just insert a "built array" node in you 1D array and it will turn it into a 2D array with one row. Transpose it if you need one column instead
Message Edited by altenbach on 08-04-2005 09:37 AM
(2,530 Views)
