a question
I am considering using Labview to build an application soft to analyze
voice, using the
microphone of the computer as input, is it possible?
Thank you in advance for your answer.
(2,789 Views)
It depends on what "analyze" means.
In LV 6 you have some helpful functions for managing audio I/O (located in Functions > Graphic & Sound > Sound palette).
If you are thinking on something complex (like speech recognition), check this post [http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000F8350000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0]
Hope this helps.
(2,789 Views)
rong;
You may want to take a look at LabVIEW Signal Processing and LabVIEW Sound and Vibration toolsets.
Regards;
Enrique
www.vartortech.com
(2,789 Views)
