abort execution w/ labview database
I have a labview application that reads and writes to an access databse. I have a go button that continues the program after its running. Now, is there any danger in just using the "abort execution" button on the toolbar everytime i want to close the program? what if the program is just "x"-ed out everytime?
thanks,
(3,235 Views)
It is generally NOT a good idea to use the Abort Execution. It is better to provide more control when stopping a program and make sure all reads/writes are completed, references are closed, etc. You can use the Event Structure to trap the "X" and do an orderly shutdown.
(3,235 Views)
My program stops by itself once the write is completed. I wanted to try to make the program continuous (thats why I asked about the abort execution). The program is alright if it just runs once and stops right? Also, how would I "trap the X"?
I uploaded one of the program examples.
(3,235 Views)
Instead of running the program continuously by selecting the Continuous Run button, put your entire code in a while loop and have another Stop Boolean conotrol button.
You can use the Event Structure if you have LabVIEW 6.1 or 7 to detect user generated events. There you can set up the code that ends the VI if the user closes the VI by clicking on the X in the top right corner.
Zvezdana S.
(3,235 Views)
