abortion execution property node
Norbert: The privat functionality is required to get the context/ApplicationInstance of the blocking VI. Here is the link to Darren's nugget
Further down the page, Darren explains a bit about the private functionality that was needed and shows the code of the 'public' parts.
Felix
Message 21 of 22
(1,214 Views)
Ah, ok, you are right. My version does not support application instance comprehensive (is this really an english sentence???) abort of VIs....
Nevertheless, i usually use only a single project at a time to prevent unintended cross linking and therefore am not likely to run into application instance issues.
Norbert
Norbert
Expert: Geometry
Message 22 of 22
(1,209 Views)
