about Table
hi everyone
I have 2 questions
1) how can I put the results in colone and not in row
2) is there any possibility to add automaticly a Nr. for each result , like for e.g
     1    10       15
     2     0,25    0,236
     3     5,36    20
to understand what I mean plz look at the LV
Message 1 of 8
(4,424 Views)
Hi dctoni,
1) use transpose 2D Array
2) see the attachment.
Mike
Message 2 of 8
(4,418 Views)
Hi dctoni,
in 1D arrays is no difference between a column and a row.
In 2D arrays you have to use a different index at the "insert" or "replace" operation. When using "build array" you may use a transpose to change columns with rows.
To add a column with "Nr."-entries you simply use "build array"-node set to concatenation-mode (right-click)!
Message 3 of 8
(4,417 Views)
2-when i have two measures, after finishing the first one and begining to do the second, the numbers are not deleted and the count continues from where the first measure ended (see XXX)
hi everyone
Mike thank you for your reply
I succeeded to resolve thes problems i had by doing some changes in the program but I have now 2 new Problems
1) when I do the Mesurement and I save the Result , instead of having the number one on the measure i have the number one in the Title (see XX)
2) when I have two measures, after finishing the first one and begining to do the second the OLD NR. won't be replaced  with the new one on the contrary they will be added to the OLD (see XXX)
anyone have  an Ídea on how to solve the Problem
Thank you in Advance
Message 4 of 8
(4,385 Views)
Hi dctoni,
the first point is, that you have to initialize the shift register. And to solve the second point you can add an empty element to the 2D Array.
I changed this points in your example and place all functions to create the file outside the while loop.
See the example.
Mike
Message Edited by MikeS81 on 02-19-2008 06:01 AM
Message 5 of 8
(4,372 Views)
thx a lot Mike
can you plz make a screen shot of the LV and show me whith red circle where is the shift register that u initialized
thanks again
Message 6 of 8
(4,361 Views)
Hi Toni,
you find the SR and it's initialization (with empty array) in the lower left corner of the while loop!
Message 7 of 8
(4,357 Views)
ah ok
thank you
Message 8 of 8
(4,355 Views)
