about cluster element
Hello everyone ,
i am fresher for  labview . Actually i need to read the cluster element(double 64 bit data type) as string value . so because of i used function called "number to fractional string" within a while loop for continuous reading . but when i see the result zero value is getting with original value .
please anyone can suggest me what is the problem behind this one...
(2,281 Views)
You're doing it wrong.
Hard to say without seeing the code.
(2,262 Views)
This is how it should work:
Tim
GHSP
(2,260 Views)
