about enums
i have total 8 enums named as controller1 to controller 8 with 8 elements in each enum as Channel1 to Channel8. if i choose channel1 in Controller1, that should get disabled in the corresponding controllers (i.e 2 to 8 ).like that it has to fallow... but when u dont choose anything for a particular enum , it will be at its first element Say "NA " and this shud nt get disabled in the corresponding enums.can anybody help me out....... i have attached my code..... i have done most of the part.... bt it is not working as i wished....
thank u.
(3,856 Views)
You have not attached any code. Yoou have attached something in a proprietary format.
(3,847 Views)
i have attached my code nw..... thanks fr the reply
(3,833 Views)
I've solved your problem and posted it in the other post you made on this subject.  This is why it is best to just make one post.
- tbob
Inventor of the WORM Global
(3,803 Views)
