acceleration to displacement
Hi Henrik
I have a servo-hidraulic machine and a can put it doing a sinusoidal movement, for example 0.5mm amplitude and 5Hz.
I try to get the sinusoidal with the geophone, but nothing appears a sin wave.
Could be the high voltage in geophone? Can you change the circuit to reduce more the input voltage in geophone?
Are the machine parameters good for testing or should I change it?
Best regards
Carlos Palha
Message 31 of 34
(975 Views)
@cpalka wrote:
Hi Henrik
Best regards
Carlos Palha
A sine at 5 Hz with 0.5 mm displacement amplitude results in ~16 mm/s velocity (and ~0.49 m/s²) with 28 V/m/s sensitivity the expected voltage output amplitude is ~0.45 V.. well within the range.
The IEPE sensor should be (@~1 mV/m/s² sensitivity)  ~0,5 mV amplitude.
Increasing the frequency to 16 Hz @ 500 µm amplitude results in v=~50 mm/s and a=~5m/s².
Another point: Do you have the bare geophone, or is there already a damping resistor included?
Do you have a scope you can hook on?
Greetings from Germany
Henrik
LV since v3.1
Message 32 of 34
(961 Views)
Hi Henrik
Thanks for the good explanation
With 5Hz and 0.5mm (0.25mm amplitude) and an accelerometer I get similar results for displacement.
About geophone, I can get good results  (I think it is input voltage)
I use a bare geophone
What you mean scope to hook on?
Message 33 of 34
(951 Views)
Hi Henrik
Seems geophone works fine for freq upper than 10Hz.
With your circuit the signal changes a lot for better.
With machine at 10Hz and sin .4mm (0.2mm Amp) and adjusted sensitivity for 19mV/mm/s it gives an Amp= 0.199 to 0.201mm
With 8Hz and 0.6mm  the geophone measures about 0.22mm
With 15Hz  0.3mm  the geophone measures about 0.16mm
With 15Hz  0.2mm  the geophone measures about 0.11mm
Message 34 of 34
(939 Views)
