access Web services SOAP
I try to communicate with OMICRON TICRO100 using labview. It is possible to communicate with this material using JSON or SOAP commands. I managed to send JSON commands using labviewHTTPClient.lvlib Get.vi. Unfortunately, only 4 commands are available with JSON, the other are available using SOAP.
Therefore, i used the labview tool to import and generate automatically the API using the WSDL file. The tool generated an API with all functions , but when i try to use the API ,i open the web service, and call  one function i get error 1172 (HTTP 417: Expectation Failed. ).
In the TICRO documentation, i read i have to parameter this:
//T  // TICRO web server does not support the headers otherwise
System.Net.ServicePointManager.Expect100Continue =false;
 How can i do that ? I found the .NET class, but there is no property in the API generated to change this property.. Maybe someonen has another idea ?
Thanks for your help!
(3,614 Views)
Hello kabooom,
Were you able to find a solution for your question ?
Clement Dekeyser
(3,560 Views)
Hi Cdkey...
I didn't manage to use the vi generated by the tool.That's a shame because the tool looks great ...
Finally i used a simple http post command. I used soapUI tool to have the xml string to post and easyXML from jki to generate the string. It works, but any idea to use the vi generated is welcome..
(3,557 Views)
