access database data not stored in tested order
I'm not a database expert so forgive the question if it's a stupid one. When I turn on database logging and run my sequence the data isn't always stored in the tables in the same order that it was tested. This is very frustrating when I have multiple loops on a particular parameter. Am I doing something wrong? I realize I could correct the problem by keeping track of the loop dynamically but that's extra work.Smiley Mad
kph
(2,691 Views)
What database are you using.  Access will typically order the records by when they were written.  SQL won't.  The best way to do it is to have a primary key defined.
(2,677 Views)
That's good to know Brian, but I'm using Access. I think this is a TestStand issue. When I get time I'll run an experiment to see if I get it to reproduce consistantly.
kph
(2,669 Views)
