access logs from a headless data logger
I want to implement a headless data logger and access it's files via Ethernet without using a host VI on the PC that will be connected in the network. How can I implement this?
(3,695 Views)
Accepted by topic author FyrewurX
Install a FTP server on your "headless data logger"…
(3,667 Views)
You did not say what OS your headless logger was running so I will assume it's Windows.
Just share your data directory on the network, or put your data in one of the "Public" folders in Windows 7 and up, Eitherr way you can then use Windows Explorer to transfer the files.
=== Engineer Ambiguously ===
(3,637 Views)
We run LabVIEW Real-Time using a PXI as the "headless data logger" (it actually does a whole lot more than just log data).  From Windows, we did an "Add Network Location" and specified "ftp://10.1.0.101/" (or whatever was the IP of the PXI).  It then showed up as a "Device" in Windows Explorer, and if we clicked on it, we could see all of its files and folders and use "drag and drop" to transfer back and forth.
Bob Schor
(3,587 Views)
