access organisation in VI Server
Is it possible in VI Server Method to make access "order"? Like in Web publishing tools. When I share my front panel in the Internet, users can't use front panel together at the same time. They are waiting when nobody use it and then they can control it. I'm trying find the way, how can I use or make same "order" for VI Server. I'm using "Client - VIServer Example.vi" and "Server - VIServer Example.vi" examples. And when few computers with "Client - VIServer Example.vi" can access one "Server - VIServer Example.vi" at the same time this is problem. It is not a problem for exactly this examples , but this is a problem if I modify this examples to control Hardware!
(2,821 Views)
You've asked basically the same question in this thread and also this thread.
Please stick to one thread.
(2,812 Views)
It is so nice from you, to show me something  that I already know! But if you will look carefully, there are no any answers. That's why I tried to re-ask my question in different, may be more understandable form.. It will be better, if you can help me in my question. But anyway.. thanks for at least such respond.
(2,802 Views)
Give some time for people to answer your questions.  If it is something a little bit out of the ordinary, fewer people will know how to answer it and it will take a bit longer for someone who does know how to answer to respond.
By asking the same question mulitple times, all you are going to do is tick off people once they answer one of your questions only to later find out other people had already answered you other questions.
If you need to clarify your question, do it in the same thread.  Then once the right people see it and are able to help, then they are effectively working together to help you rather than independtly going off in different directions and duplicating each other's work!
(2,789 Views)
Yes.. that's make sense. Next time I will do it by such way!
I'm sorry for such many questions; I thought I'm doing in the normal way. I will improve it! Thanks for your attention!
(2,779 Views)
