access plot colors programmatically
Emily,
I placed the case structures and the arrays into my vi.  I am still missing something.  I have attached the vi and the front panel.
Ron
Message 21 of 30
(2,857 Views)
Emily,
Do I still need all of the property nodes as well?
Message 22 of 30
(2,855 Views)
Emily,
I think I answered my own question...YES.  I added the property nodes for 'plot visible?' and 'active plot'. and it works except for one small detail. The  colors are all off by one.  I want red for the first trace, then blue, green, magenta, aqua, and finally mustard.  The first plot boolean button brings up blue!  Then as I go down the buttons turning them on, the colors are all off by one and the last button that is supposed to be mustard brings up red!  Also, there is no rhyme or reason to the colors that show up in the array chart on the front panel.
Ron
Message 23 of 30
(2,853 Views)
Emily,
Here is my code with the arrays and the property nodes.  As I stated, the colors are all off by one.  The top red button gives me blue and so on down the list.  The mustard colored channel gives me red.
Message 24 of 30
(2,844 Views)
rwbrook@integratedps.com wrote:
Emily,
No, that's not code! It is a MS word document containing a screenshot. Please attach the actual VI.
There is no way to tell from the picture how your color array looks like, because we cannot tell the size of the arrays. I also see quite a few race conditions.
Also remember that property nodes execute to to bottom, so if you set the property before setting the active plot, things will lag behind by one iteration. the "active plot" property belongs on top. I am also not sure why you are doing each node twice. If you would use an array for your booleans, you could do it in a loop using a single instance of the property node. Simplify!
Message 25 of 30
(2,837 Views)
You are correct, of course.  The reason for two property nodes for each color is; one is for the time waveform overlay and the other is for the spectra overlay.
I will reverse the calls in the property nodes.
Message 26 of 30
(2,828 Views)
Here is my code.  The 'ChooseReadDataPlotColors.vi is a channel selector so only one channel can go into the peak search routine.
The 'finalvibes.dat' is six channels of fft data.
I will send another post with the time data and the overalls and rpm data.
Put all three data files in a folder.   when the program asks for the datafile, open that folder and change the files type to *.*.  Then just double click on the finalvibes.dat file .  The other two are automatically selected.
Ron
I couldn't post dat files, so I tried to change the files to a .txt and it still adds the .dat.
So, how do I attach an example data file, zip them?
Message 27 of 30
(2,824 Views)
My vi did not go.  Here it is.  There is also a custom subvi that I made to choose  one channel for the peak search routine.
Message 28 of 30
(2,822 Views)
Yes, put everything in a zip file...
Message 29 of 30
(2,820 Views)
Altenbach,
It never fails, I will be in the field all day tomorrow.  I will be in the office on Friday.  If you have any questions on running the vi, send me an email.
Ron
Message 30 of 30
(2,819 Views)
