Is there a way to do the following:
- access the (x,y) coordinates of a plot cursor so that I can use them further in the program? I need to mark certain points in a plot and store them in an array. Right now I have to copy them by hand(!) from the cursor legend, and then paste them as the elements of the array.
-access the scale of the plot (set on autoscale), for example the y-scale? I would like to be able to run a while loop (where data is acquired) until the |max| of
the scale is above or under a specific value.
Thanks a lot!
