accessing FT2223D ACBUS and BCBUS pins in labview
i am d2xx labview functions for an ftdi projectz and am working on an FT2232D ftdi chip..does anyone know how i can read the  ACBUS[0..3] pin levels and BCBUS[0...3] levels?..if am not wrong the create device list function only allows me to access the ADBUS and BDBUS pins..thanks
(2,675 Views)
*i am using.......(sorry)
(2,672 Views)
*project
(2,671 Views)
so you are calling d2xx driver in LabVIEW? Are you using the LabVIEW example provided on their site?
The functions inside the driver are not supported by NI since the library was developed by FTDI, anyway you can find a programmer guide here with a list of all the driver functions.
I hope this helps!
Bye,
Licia
(2,649 Views)
thank you you for your reply,apparently i was unable to resolve my problem from the the programmer's guide because it does not seem to contain information on how to configure ACBUS and BCBUS..but thanks for your attention and advice,
(2,638 Views)
