accessing the fielpoint web server using serial port
hello everyone!
I would like to use the fieldpoint serial port, instead of the utp port, to
access the fielpoint internal web server. This means to have the tcp on
serial port. Is it possible? And how can I do it?
Andrea
(2,578 Views)
There may be some hidden trick method of doing that, but usually, RS232 does not support web access. In order to use a COM port to access the web, you'd normally have to use something like PPP. I don't think there's a PPP client for FieldPoint.
- Dan
(2,578 Views)
