accuracy of wait(ms).vi
If I insert a 100ms wait, what is the minimum error I can expect, +/-1ms? ie - 99-101ms wait?
What would be a common worst case scenario?
(2,701 Views)
That depends on the OS that you are using.
The best you can expect is 100ms, but the worst in theory is infinite.
(2,701 Views)
This is because Windows can always make the LabVIEW application wait while it does something else which in theory could make LabVIEW wait forever.
(2,701 Views)
Hi Jeremy,
I saw lot of your postings related to setting priority of VI's and sub VI. I dint know how to get your e-mail address. So I have posted my question as a comment of this mail. This question is not related to the earlier posted question.
I am performing 2 time critical counter operations. I am using software time due to the hardware limitation of PCI6013(I have tried all other options). My problem is that I get a erractic value when I use mouse, keyboard or change to other application.
I found your following link providing a method to provide maximum priority to labview application.But you have asked even regular labview users not to use this application. I am not even a regular LABview user. Is there any precaution that
I should take to use this VI. I am in need of such an application very badly. Please Help.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000F5880000&UCATEGORY_0=_15_&UCATEGORY_S=0&USEARCHCONTEXT_TIER_0=0&USEARCHCONTEXT_TIER_S=0&USEARCHCONTEXT_QUESTION_0=priority&USEARCHCONTEXT_QUESTION_S=0
(2,701 Views)
