acquiisition voltage levels in 6551
Hi everyone,
I am using a 6551 to write and read an eeprom. It seems that if i feed the eeprom with 2.5V, the 6551 won't notice the "1s" in the signal; it's acquired as "Zs".
So i fed the eeprom with 5V, and i can write and read.
My question : is it possible to chose (more particularely here lower) the threshold of detection of the 6551?
Johanna D.
Message 11 of 12
(444 Views)
Use the niHSDIO Configure Voltage function found in Measurement I/O - HSDIO - Acquisition - Configuration palette.  Two ways to set it up:
1.  Set the polymorphic selector to Data - Custom Levels.  Set the high level input to 1.5 volts and set the low level input to 0.8 volts
2.  Set the polymorphic selector to Data - Logic Family.  Set the logic family input (an enum) to 2.5V Logic.
- tbob
Inventor of the WORM Global
Message 12 of 12
(431 Views)
