acquire a signal with two differents rates
You are the one that wants to have a different sample rate. Why? The reason for doing so would make the choice pretty obvious I would think. Do you want to reduce the number of samples (Align and Resample) or make it seem your acquisition time was twice as long (simply changing the dt).
Message 21 of 24
(668 Views)
As Dennis said, Motorbreath's example is not a good example.
Use Align and Resample.  It works.  Attached is a screen shot showing the before and after of a simulated sine wave and how the Express VI was setup.
Message 22 of 24
(667 Views)
I wanted to acquire a signal with two differents rates because for example with the low rate , i will acquiere all the signal during a long time and if i need to take a part of this signal with more precision, i will use the high rate. So I think the VI align and resample is mu solution, it works.
Thank you very much for your help
Romaric GIBERT
Message 23 of 24
(659 Views)
If the acquisition time is important, the suggestion I made is not useful, let me say.
It is an easy way to resample acquired data.
If timing is vital, I would recommend building your code into C. If not, if you can post-process your data easily, it is an option to do as i said.
Ozgur
Message 24 of 24
(646 Views)
