acquiring pressure data using daq assist
Hi all,
I want to use DAQ Assist to measure the pressure.When i select DAQ Assist>Acquire Signals>Analogue Input>Pressure>Pressure(Bridge) then is says 'no supported devices found'
What should i do?
thanks
(3,203 Views)
What data acquisition devices do you have?
You need to have a device that can acquire bridge type signals.
(3,186 Views)
I have NI USB 6229 type DAQ
(3,172 Views)
That has normal analog inputs, so of course you can't connect a bridge type measurement to it.
What is your pressure sensor?  How are you connecting it to the DAQ card?
(3,168 Views)
I have Trafag pressure sensor anyway i give up doing it by daq assistant.I did it by using another daq tools.But now i have a new problem in calibration of sensor so i will post a new question 🙂
(3,164 Views)
