acquisition FPGA
hello !
i've got some problems to understand how to acquire a signal properly, i've got a FPGA 7951R and a module NI5731. I generate a  500 Khz  sinewave with a fonction  waveform generator, and i plug it into the Analogic input 0 of my module 5731. And i would like to see it into a graph on my FPGA ( see picture attached). i understand that the numbers on the Y axe is the number of samples i got, but still don't understand how to manage the timing loop and the number of sample of my graph ( Y axe ) to get the proper waveform at 500 Khz.
Any help ? thx Smiley Happy
(4,050 Views)
Try using a timed loop rather than a while loop on your FPGA diagram. You are not generating samples at a regular internval inside of a while loop, but inside of a single cycle timed loop you will. See the 'High-Performance Programming With the Single-Cycle Timed Loop' section that starts on page 15 of the High-Performance FPGA Developer's Guide for an in depth explanation.
The NI LabVIEW High-Performance FPGA Developer's Guide
(4,028 Views)
it's not really better, but for axample, see attached, i acquire a 5Khz signal, and if i put 200us into the count module and if i put 300 samples ( Y axe of the graph) i've got 1 periode but i would like to know if what i see is a 5khz signal or not 😕  i'm trying to find an example of acquiring a signal with the NI5731 module but i don't find any Smiley Sad any help ?
thx
(3,999 Views)
There is a getting started example for the 5731 in the example finder. Go to Help>>Find Examples to open the example finder, from there you will want to navigate to Hardware Input and Output>>FlexRIO>>IO Modules>>573x>>5731 and then open the getting started example.
(3,966 Views)
hello David,
I know that, but the problem is that i don't have this one ( see attached):smileysurprised:
(3,951 Views)
If you are missing the examples for the IO Modules then you will want to install FlexRIO Adapter Module Support. You can find it by going to ni.com/downloads and doing a search for FlexRIO. Here is a link to the most recent version (4.1) that you can use if you are using LV 2012 or 2013.
NI FlexRIO Adapter Module Support 4.1
https://www.ni.com/en/support/downloads/drivers/download.ni-flexrio-adapter-module-support.html#3243...
(3,936 Views)
