acquisition from DMM PXI-4072 and PXI-6120
I have to acquire two signals: one from DMM PXI-4072 and another from a channel of DAQ PXI-6120.
I have labview 7.1.
Please could someone help me?
Thanks in advance
Raf
(2,999 Views)
Did you allready had a look at some examples? (LabVIEW>Help>Find Examples)
Christian
(2,992 Views)
Thank you for reply.
I didn't find anything in examples.
Please could you tell me some vi useful for me?
thanks again
(2,989 Views)
Ok, from scratch on you will need to have the NI-DMM as well as the DAQmx driver installed. I'm out of office so I can't tell you right now which versions of them are compatible with LV 7.1, you will have to check the readme.
Using the Example Finder then you just need to type DMM or 4072 for examples and Analog In or just analog to get the 6120 examples.
Hope this helps,
Christian
(2,985 Views)
