acquisition speed
Hi
I am using 6024E card.
i am using 4 digital input and one analog input.
the speed of the card is 200kSamples/s
so what is the maximun speed in each line?
Thanks for help
(2,669 Views)
Unless spelled out specifically otherwise,
you should assume the specified sample rate is for the A/D converter. If teh board has one A/D that is shared for multiple inputs the sample rate of the A/D must be divided by the number of inputs.
Therefore;
(200KS/s) / (4 inputs) = 50KS/s/input
Ben
(2,669 Views)
