acquisition usb 6251
hey everyone,
My name is Marek
Please help me solve my problem.
Whether it is possible using a NI USB 6251 doing data acquisition and graph display of real-time of the sine signal of variable frequency within the 0-30kHz? Please advice what should I use: DAQmx blocks or Assistant DAQ  or even something else?
I would like to have a real-time measurement.
Best regards.
(2,432 Views)
If you are a beginner you shoud use the DAQ assistant otherwise you have the DAQmx functions. I invite you to start with those tutorial :
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Do I Need a Real-Time System?
Message Edité par Steve M. le 02-04-2010 10:06 AM
Steve M.
(2,391 Views)
