activation code not working
Having problems with activation of LabView 2010 on the additional HD.  I have a computer with a single removable HD slot and am creating a backup HD with windows XP installed as well.  The activation worked fine with the first HD but with the second one it generated a new computer ID.  I used this ID to get the activation code, but the code does not seem to work, get an error activation code does not correspond to product.  Do you know if they allow you to install this with more than computer ID as I also have a third removable HD that I would like to install everything on as well, all to be used on the same computer.
(3,195 Views)
Why are you installing it on multiple hard drives?  Why wouldn't you do just a straight backup copy from the drive it was installed onto to the backup drive?
(3,183 Views)
thanks for the reply, got it working,
(3,181 Views)
what'd you do ?
(3,089 Views)
