active X object with a program to see my USB camera alive
I´d like to use an active X object with a program to see my USB camera alive. I don't know if it is possible, does anyone could help me to do it?
I have a program to use with my camera but I don't know what object I have to insert in the Active X container to play it.
It could be another program, you suggest.
I tried another solution before but it didn´t work: http://forums.ni.com/ni/board/message?board.id=170&message.id=397511
So I thought it could be done in this way.
Thanks in advance.
Celia
(3,821 Views)
Find attached the vi for acquiring the image from webcam taken from the forum.
Post back for queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
(3,795 Views)
Thank for your help, but it didn´t work.
But I've got a way using Imaq, it is an attchment. The difference from the others is the Imaq USB PropertyPage.vi. Even if I cancel the dialog box it works, but it don't work if I don't use it. As I don´t want the dialog box opens I am figuring out how to eliminate the Imaq USB PropertyPage.vi, what kind of configuration i have to do...
Thanks again,
Celia
(3,724 Views)
