active plot
Hello
What does 'active plot' in a property node for an graf mean?
/ Peter
(5,228 Views)
Hi Peter,
since you can have multiple plots going to a graph (or strip chart) it would be difficult to anticipate the number you might use. If this was done, then a property per plot would be needed for things like plot colour, style etc. You can imagine how out of control that would get for 30 plots in the properties selection!. It's more convenient to tell the object that whatever you're going to play around with on a plot's properties is with respect to the Active Plot.
Hope that helps
S.
// it takes almost no time to rate an answer Smiley Wink
(5,228 Views)
G'Day Peter,
I've attached a VI that is a basic demonstration of what "Active Plot" does - run the VI, select the "Active Plot" and then change its colour. You can the select the other plot, and change its colour instead. Setting the "Active Plot" property node tells the system which plot you are referring to whenever you use further plot property nodes.
Like my Answer? Give it a Rating!
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
Int'l Voicemail & Fax: +61 2 8080 8132
Aust Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necess
arily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(5,228 Views)
