active vibration control of a cantilever beam
hi , im working on active vibration control of a cantilever  beam , and i need to generate a signal through a pid controller in labview which is opposite to the input vibration to the beam, this signal will then be provided to an actuator which will provide opposite vibrations. Im taking an analog input through a daq assist and outputing it to the actuator again through a daq assist, im attaching the vi ...
Pls help
thnks
Kunal
Message 1 of 1
(2,485 Views)
