active x y field
Is it possible to create an active xy field on a screen that with the movement of a mouse cursor within this field could operate 2 proportional valves (one on each axis) being +-10v on the x and y respectively. These proportional valves would be powering individual  hydraulic cylinders each with linear positional feedback which could be routed back into labview for positional monitoring. Im basicly trying to control an arm with the mouse cursor.
(2,848 Views)
Sure. All you need to do is to respond to the MouseMove event. You can place, for example, a picture box to act as this "field". Attached is a simple example in LV8.2. There's lots of other ways to do it.
(2,843 Views)
Many thanks for this, its a project Im playing around with to demonstrate accuracy and precision of our servo valves.
(2,840 Views)
