active x
Bonjour,
Je n'arrive pas à utiliser les noeuds de propriétés d'active X, je pense que celui-ci n'est pas activé. Comment faire pour activer Active X sur Labview?
Merci de votre aide.
Quentin
Message 1 of 9
(5,477 Views)
There is no way to "activate" ActiveX.  Could you be more specific (in either French or English) about the problems you are having?  What ActiveX component are you trying to use?  Are you trying to place it in an ActiveX container on the front panel, or open it with Automation Open on the block diagram?
Message 2 of 9
(5,462 Views)
Bonjour,
Merci d'avoir posté votre question sur les Forums de National Instruments.
Cette partie du forum est réservée aux posts en anglais. Si vous souhaitez poster en français, je vous encourage à utiliser la partie francophone du forum.
Now, I'll write in english for the sake of the other users.
As Nathand wrote, could you be more specific about what you are trying to do ?
ActiveX node are always usable inside LabVIEW so I guess you are not doing things in the right way.
If you could show your program or give new information, it would be very helpful to better understand your issue.
Guillaume H.
National Instruments France
Message 3 of 9
(5,443 Views)
Sorry for my mistake.
My problem is that I would use the Excel Automation, but when I create my VI and I use "Knot Property" or "Knot of method", I don't have choice to select a parameter.
Do you have a idea to help me?
Thank you
Quentin
Message 4 of 9
(5,432 Views)
I have used ActiveX automation with Excel, but I have not idea what "Knot of Property" or "Knot of method" is.
Message 5 of 9
(5,424 Views)
I think this is what the OP meant:
Knot of Property: Property node
Knot of method: Invode node
Ben64
Message 6 of 9
(5,422 Views)
yes it's that
Message 7 of 9
(5,419 Views)
Voici un point de départ. Note that to use Excel ActiveX automation you will need to develop the knowledge of the Excel ActiveX objects methods and properties. A good startup is to look at the MSDN website.
Ben64
Message 8 of 9
(5,414 Views)
Thank you very much
Message 9 of 9
(5,391 Views)
