activex control and tab control
I am using a two page tab control. I place an activex control on one page. the activex renerates images. When I run the vi, the activex control appears on both pages. I only want the control to show on one page. Can anyone help me? The control correctly shows on one page when the vi is NOT running.
(3,373 Views)
I have seen this problem in the past. What version are you using? I know it was fixed in version 7 and I think it was in version 6.1, but I am not sure.
(3,373 Views)
I am using version 6.1
(3,373 Views)
I don't have 6.1 in front of me now. I came up with a workaround for my application when I encounted this problem. I created an attribute node for the container and the tab control. Whenever the tab control was not on the page with the control, I made the container invisible. This then hid the activeX control.
(3,373 Views)
Another document that talks about how to solve this problem (although it shouldn't happen in LabVIEW 6.1, only earlier versions):
How to Place an ActiveX Container on a Tab Control?
http://digital.ni.com/public.nsf/websearch/DC228B209893C41F8625694600679326
Hope this helps.
(3,373 Views)
