activex help!!!
I use an Euresys Piccolo Pro 2 card to access to a camera. With the card I received some activeX.
I want to use them in Labview, but I don't know how to do it!
I have some samples written in visual c++, but I can't open them in Labview?
Help!
(3,754 Views)
boryszew,
if you like to use ActiveX-server in LV, you need to know how to include and program the server. There are some examples delivered with LV which show you, how to manage this. You can find one example here [broken link removed; example no longer available] or some more in your example-browser. A very common example for ActiveX is the usage of Office from LV (like the one i linked).
hope this helps,
Norbert B.
NI Germany
Norbert
Expert: Geometry
(3,747 Views)
boryszew,
sorry, i inserted the wrong link. The link i wanted to add is this [broken link removed; example no longer available] one.
Norbert B.
NI Germany
Norbert
Expert: Geometry
(3,743 Views)
