activex
Hi guys,
I've done a small vi that prints a pdf-file through activex. It seemed to work fine (and showed to be quite similar to a posted vi on the forums), until i called it from another vi, that is.
I got the error "Must be a user interface", which i set through vi-properties.
I got a empty window hanging which didn't close until labview was closed, which seemed to be a timing issue, so i've added a 3 sec delay to be sure acrobats activex-control is loaded before closing it.
Now, the real problem which i cant seem to get around:
When the activex-control is called, it opens Acrobat Reader (as a separate window), and i dont want it to do that. If it has to, i atleast want to keep it minimized and/or closed afterwards.
Any ideas?
/Y
Qestit Systems
Certified-LabVIEW-Developer
(4,092 Views)
Please post what you have did so for or just give a screenshot
(4,089 Views)
So far:
"print-test" uses my "print pdf" to write a .pdf and acrobat reader opens and never closes. If minimized it pops in front.
Qestit Systems
(4,085 Views)
Accepted by topic author Yamaeda
After some more "fishing the sea" (searching the internet), i found out it's a Acrobat-bug. Apparently it happened to alot of VB-people using Acrobat 8 (guess what i'm using).
I tried installing version 9, and now it's perfectly silent, no Acrobat window opens at all.
However, i'm not sure which versions will be at the users computers, so i added a small hotfix. After printing, the Appliction does a "Bring to Front" so regardless if i get the Acrobat window or not, the VI will be in front and accessible.
/Y
Qestit Systems
(4,039 Views)
Excellent. Thanks for the update. Tossed you five (Sorry now kudos).  Smiley Wink
(4,035 Views)
