acton serial
I'm trying to control a very old acton monochromator via a spectradrive module over serial port.  I can control it with their software, and I can control it fine with hyperterminal, but for some reason, I can't get it to work with VISA in MAX.  Any suggestions (I have it set to 8-N-1 as the manual specifies, although the manual also specs 1 start bit, which I don't see an option for in MAX)?  Aargh. Thanks
Message 1 of 16
(5,624 Views)
I believe Start bit is always 1 bit.  I can't remember the last time I had seen Start bits mentioned a serial specification before.
Are you getting any errors such as timeout errors?  If so, post the error code numbers.
Do you need to append a carriage return or linefeed to your query?
Are you sure the baud rate is set correctly?
Message 2 of 16
(5,618 Views)
It is an old monochromator.  We have 2 more like it (but GPIB controlled), but I cannot pry them out of my coworkers hands.  All of the example programs in the manual are written for GPIB (and not in Labview).  How do you append a carraige return or linefeed in MAX (or in a VI for that matter?).  I set the baud to the specified 9600.  J
Message 3 of 16
(5,614 Views)
I think I found my problem.  Somehow, I had the wrong flow control selected... Thanks.  J
Message 4 of 16
(5,612 Views)
I forgot about flow control.  It seems like most modern hardware doesn't require it.  But I guess that "very old" hardware did.  Glad to hear you got it working.Smiley Happy
Message 5 of 16
(5,609 Views)
i'm working on a rather primitive acton-research monochromator as well. Maybe we can share our knowledge on it Smiley Wink
Message 6 of 16
(5,592 Views)
Sure... we can kkep using this thread if you'd like.  I'm having a bit of luck now, but my program isn't super robust.  Sometimes it works, sometimes it doesn't.  What model monochromator are you using?  J
Message 7 of 16
(5,577 Views)
SP-150.....hopefully we have the same model Smiley Happy
Message 8 of 16
(5,570 Views)
I'm using a spectradrive external controller to run a spectrapro 500.  I'm sure that the communication is similar, though.  J
Message 9 of 16
(5,568 Views)
hi, I have the same spectrapro 500 and tend, to connet it as Juanni had made with the RS232 port . As noticed in the usual manual I used the cables and connection. The main problem is that I can’t receive any data from the device. In order to communicate with, I use the Visa without any success.
Do you have any idea on the origin of my problems.
Message 10 of 16
(5,403 Views)
