actuating control values on front panel
i've got a problem with actuating control values on front panel.
actuating one seperate control value from a sub vi is not a problem. i use a referencez and it works.
now i have too much controls in my sub vi.
is it possible to reduce my sub vi connectors by combining several controls or references?
thx
markus
Message 1 of 9
(3,681 Views)
Yes,
A good way to combine controls (including different types) is to use clusters.
R
Message 2 of 9
(3,676 Views)
Tank you for your fast answer,
but i think thats not the solution of my problem. if i have a cluster all my controls are in the cluster.
on my front panel i have a lot of controls which cannot be in one cluster.
markus
Message 3 of 9
(3,673 Views)
You don't have to use clusters directly on your main VI's front panel. You can bundle the controls in your block diagram and pass a cluster to the subVI. Smiley Wink
Message 4 of 9
(3,662 Views)
i think it is not the solution. when i pass a cluster the sub vi the controls will only be actuated when the sub vi finished. my problem is that my test runs in a sub- vi and i want to see the current values in my front panel.
for only a few controls i can use references. but i have too much controls and i want to bundle them.
markus
Message 5 of 9
(3,633 Views)
You can pass the reference to the cluster to the SubVi to make it get updated on the fly.
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 9
(3,624 Views)
Lets see if an image can help clarify.
A) The front panel Object
B) The terminals to those object
C) Reference to the control are packed in a cluster
D) and manipulated in the sub-VI
Ben
Message Edited by Ben on 09-23-2008 06:01 AM
Message 7 of 9
(3,620 Views)
Thank you for posting. I tried it but it didn't work. can you make a screen shot or something else?
markus
Message 8 of 9
(3,618 Views)
Hi Marcus,
See to the attached VIs.
Message 9 of 9
(3,613 Views)
