actuator program
Hi
Never mind i got it working.It works now.Thanks for the tip Ryan 🙂
One thing i wanna try here is to input the breaths/min. and divide by 3600 to give me the 'time delay for each condition.Any suggestions how i could input the breaths/min value and use that to calculate my time dealy.Here ive attached my program.
Message 11 of 12
(1,062 Views)
Hi amatuer_actuator,
You should be able to wire the control straight into the case structure (with what we call a Tunnel).  You could also wire from the selector of the case structure.
Be careful with your divide, its the top number divided by the bottom number. As you have it wired, it would be 3600/(BPM).  You should also be careful as to which timing VI to use.  The Wait Until Next ms Multiple is slightly different from the Wait (ms) and could cause behavior that you do not want.  The context help (Ctrl+H) and the detailed help explain this more.
I hope this helps.
Message Edited by Neal M on 03-05-2008 10:32 AM
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
Message 12 of 12
(1,028 Views)
