adaptive contro theroyl
Hi there ...i have a problem with implementing adaptive control using labview 8.5 to control the DCMCT Qnet motor
i opened new disscusion plz have a look
http://forums.ni.com/t5/Motion-Control-and-Motor-Drives/Adaptive-control/m-p/1251666
Regards
Message 11 of 28
(2,093 Views)
It would be super helpful if you could post your code.
--Michelle
Message 12 of 28
(2,072 Views)
here is my code  and as i mentioned im using DCMCT qnet motor with labview 8.5
the problem is connecting ARX system identification method to adaptive method and be able to find the PID gains from the Transfer function.
thank you for your help.
Message 13 of 28
(2,059 Views)
Hello Aswwa,
Could you also include the subVIs that you used in your main VI?
Andy Chang
Message 14 of 28
(2,041 Views)
here is the project .
Message 15 of 28
(2,031 Views)
sorry abput the above project ....
this one is the complete one
Message 16 of 28
(2,016 Views)
It seems that you are trying to pass single points into ARX and that it probably needs an actual array of points or a waveform. Are the array stimulus and response signals the only inputs you have questions about? I take it the output model it creates doesn't look right to you either? I am not an expert on this and will need to talk to someone else and post back.
--Michelle
Message 17 of 28
(1,964 Views)
yes that is one problem and how can i get the PID gain for my controller from the estimated transfer function
thanx alot for your help
Message 18 of 28
(1,954 Views)
I'm not sure what you want to accomplish with ARX sys id. You already defined, with matrix controls A,B,C and D, the transfer function that you are trying to identify. Only one value for stimulus and response is not consistent with ARX and also conversion from ARX model to TF is done with SI Model Conversion.vi
cosmin
Message 19 of 28
(1,940 Views)
hi,
im tring to adapte anychanges in the system and A,B,C,D are initial model of system
Message 20 of 28
(1,934 Views)
